Disc Brake setup advice needed-rubbing
479 Views 3 Replies 2 Participants Last post by  ataylor
I am setting up a used set of Hayes Nine's on the front of my bike. I can not get the rotor to stop rubbing. I have pried the pads open with a screwdriver, I have loosened the mounts spun the wheel and applied the brake then tightened the mounts with the brake lever squeezed, I have done the same with the two other allens on the caliper. The best I can do is get the wheel to spin with only a little rub but as soon as I apply the brake the rubbing is worse again. The wheel will not spin. Are the pistons sticking? I have no idea what to do next. Any advice would be greatly appreciated.
1 - 4 of 4 Posts
it rubs so bad the wheel wont turn? Since they are used, they may need to be taken apart, cleaned and put a new O-ring. Have you made sure the lever is going all the way back out?
lever
the lever is going all of the way back out. I got the brake to the point now that after I squeeze the lever the wheel will turn for 5 seconds after spinning it forcefully. The rubbing stops the wheel. Where is the O-ring?
are you sure the rotor/wheel is running true? The O-ring would be on the piston.
1 - 4 of 4 Posts
