I am having trouble with adjusting my disc brakes. The bike is an 01 Jamis Eureka. The front caliper is the stock mechanical Formula, and the rear was replaced last year with a mechanical Sr. SunTour (DB-XCC-MC).
I am able to adjust the pad position and cable tension to operate properly (or so I think). The problem I am having is that they do not bite hard anymore. I am unable to lock the front or rear wheel.
I was experiencing this problem last year, and my LBS replaced the rear caliper. They were unable to adjust the caliper to bite hard as well.
As of now, the front and rear brakes behave exactly the same. Brake lever has a nice feel, and the pads are gripping, but it takes much longer than it should to slow the bike down.
I am beginning to wonder if it is possible for the rotors to wear down. It seems to me that I can not get the pads close enough to the disc without running out of travel.
I realize that both calipers are mediocre, but I know that they worked much better the bike was new.
Is there something else that I may be overlooking? Thanks.
