Im running front and rear avid bbdb 5 mechanical discs.
I've decided to do the install myself and everything is cool, but the cable tension seems off.
Initially I could pull the levers all the way to the handles, which I knew was a problem, so I went back, pulled the cable tight at the disc anchor, and then fine tuned with the cable adjust at the lever. However the cable adjust is now backed pretty far from the lever.
I get a nice firm pull now, with the lever taught about halfway to my grip, and the discs bite hard with good modulation, but I don't have much room to adjust for any future cable stretch and it makes me nervous having the the adjusters so far out. They seem pretty solid, but they are more then halfway out there.
Any thoughts . . .
lom
Any thoughts . . .
lom
