You want to replace the bolts with anodized ones? As in anodized aluminum alloy ones? If that is the case then I will tell you that I do not recommend this.
They're M5X10 bolts.
Why don't you recommend themPCC said:You want to replace the bolts with anodized ones? As in anodized aluminum alloy ones? If that is the case then I will tell you that I do not recommend this.
aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.New to MB said:Why don't you recommend them
