1 - 5 of 5 Posts
All fat, all the time.
Hey guys,
Forgive my ignorance, but are the direct mount chainring interfaces compatible or not with each other?
IE SRAM, Wolftooth, Raceface?
I ask because I'm hoping to go with the Raceface Next SL crank for my next fatbike build. Wondering if I could use a Wolftooth or AbsoluteBlack ring or are those only made for the SRAM cranks?
Thanks,
Riding rigid
SRAM, RF, White Industries ENO, Middleburn, Specialized... everyone uses a different interface. SRAM compatible is most widely available.
As for the 40/42 tooth add on for a 9 speed, It should work if it is spaced properly. I'm assuming the spacing between the last cog to the 40/42 tooth is set for 10 speed shifters, so you might need to add a little extra. Also, some that have the pickup ramps might not be aligned with older 9 speed cassettes; seeing that some are offering Shimano or SRAM specific 40/42 tooth cogs to match the ramps.
1 - 5 of 5 Posts
