You probably all know this light, solid reliable but a bit old these days :cryin:
They declared 520-600 lumens output, but looking at numbers it never have that many - it consumes 8,1W of power that means that at 90% driver efficiency led will get 2,45W.
SSC P4 @ 2,45W -> 150 lumens * 3 => 450
The light is using standard Fraen_FL3_K2 optics designed for Luxeon K2 but it works fine - inside three SSC P4 emiters on PCB board - no wonder that after some time the light became bluish.
I was wondering why nobody retrofitted that light earlier - but when I saw the driver and individual led connections It was easy to figure why.
MOD :cornut:
You need to wire up the driver :
Connect it to a modified mcpcb with three Cree XP-G R4 Outdoor White :thumbsup: .
Put everything together and go for a ride :eekster:
HIGH
MID
LOW
Outdoor shots of moded light were made in wet conditions.
