1 - 7 of 7 Posts
Looks like my ZTR Olympics can't take a few little drops, at least I found this ding the rear rim after my ride yesterday (see attached pics). The tire is fine, no flats or anything, I must have ridden for an hour before I noticed it. Is this fixable by doing something like this?
http://www.bicycling.com/article/1,6610,s1-5-32-13285-1,00.html
The alternative is a new rim I suppose and I just don't feel like spending the money right now :(
Thanks in advance.
I've had the opinion that Olympics were race-only rims.
The aluminum alloy in the rims is hard enough that when it is dented/bent it forms a weak spot.
You might be able to bend it back out to round, but it will still have the weak spot and will be even more likely to bend/break the next time.
+1
The olympic is a XC race rim, you can have a go with an adjustable spanner just don't expect perfection (or the flat spot to go away)
Discussion Starter · #4 ·
Yeah it's a strange rim choice for an AM rig (Scott Ransom, bought it used 3 weeks ago). I'm going to try bending it back, but plan for a rim purchase in the future. Thanks guys.
I had a DT swiss 5.1D rim with the same issue. I took a set of channel locks with a long handle so that torque was on my side. Real easy and got it back to 100% within minutes haven't had an issue. Now as far at the ZTR not sure.
err, 27.5+
Yep, the danger in bending back is that it could crack or totally break off the rest of the rim. If it still holds a tire then I would leave it. If it won't hold a tire then there is nothing to lose in trying to bend it out.
1 - 7 of 7 Posts
