I have this two framesets at home...
but I just don´t know which one to build ! I only have components for one frame, so I have to pick one. I hve ridden both for enough time, and I like them both a lot. Blizzard might be a better fitting size, but the explosif is nowhere far from fitting me great.Just put a straight seatpost and that´s it.
A little list of what I like from each:
(in alphabetical order
Blizzard:
Frame is newer.
Higher paint quality and frame construction(faced disc tabs,etc)
Reynolds 853.kind of riding a legend.
73mm bb shell.cleaner setup for outboard bb´s
I run discs, and the frame is disc only. So is a cleaner setup over the explosif where I have to zip tie the hose along the frame.
Explosif:
Is 1930 gms.That is 330 gms lighter than the Blizzard which is 2260 gms! I´m not a weight freak, sure, but I like to go lighter if I can. Explosif build up could stay under 11Kgms (about 24 pounds)
I could go back to V´s whenever I get sick of the discs...which is very likely to happen unless I fix the rubing issues of the xtr calipers at once!
So, what would you do?
Pics:
Blizzard:
Frame is newer.
Explosif:
Pics:
