hey, i use gasoline to clean my chains. its much cheaper, and it works great. but it may be a little more dangerous. just wondering if anyone else has heard of this. thanks!
yeah, works great, but there are the danger and environmental issues.dirtryder1000 said:hey, i use gasoline to clean my chains. its much cheaper, and it works great. but it may be a little more dangerous. just wondering if anyone else has heard of this. thanks!
Never heard cheap and gasoline in the same sentence in a long time.:nonod:its much cheaper
i take it to the place that your supposed to.mtnpat said:yeah, works great, but there are the danger and environmental issues.
What do you do with the dirty gasoline when you are done cleaning chains in it?
WD-40 is NOT a cleaner :nono: . WD-40 is a Water Displacement utility. It's good for like cleaning humidity off pawls in shifters, but not cleaning chains! For the last 12 years that I have been a mechanic I have advised DIY'ers not to use WD40 or else they end up doing this: :madman:LWright said:WD-40 works well as a cleaner although some lubes do not mix well with it no matter how long you let the chain dry between cleanning and lubing.
besides the danger from the gas fumes there is the evaporation rate, gas evaporates fast so you would get fewer cleannings per gallon than WD-40.
I have used mag wheel cleaner too.
Have not found a citrus cleaner yet that really works.
I have heard of this product and looked for it but where I used to live it wasn't available. I just moved to the west coast so I will try to find some and give it a go. Heard good things about it.newMTBer said:did you try Simploe Green?
i get those rust spots too. after re lubing and riding as you said, they disappear.newMTBer said:Dhpimp, did you try Simploe Green? I just tried it last night and it worked great. JUst be sure to relube your chain soon after and not the next morning because I was suprised to find rust spots on some of the rollers. Relubing and riding the bike seems to have rubbed the rust away, though.
Ok... compared to the rest of the western world, gas in america is still cheap. How's that?ChrisJ said:Never heard cheap and gasoline in the same sentence in a long time.:nonod:
Where is that?dirtryder1000 said:i take it to the place that your supposed to.
The only place that I have found it at is Home Depot. Try looking there, Lowes, Menards, or any other home improvement stores around you.dhpimp said:I have heard of this product and looked for it but where I used to live it wasn't available. I just moved to the west coast so I will try to find some and give it a go. Heard good things about it.
You have something to back that up with?dhpimp said:Using GAS will actually deteorate the nickel plating on your chain and weaken the metal. .
Must not be looking too hard.newMTBer said:The only place that I have found it at is Home Depot. Try looking there, Lowes, Menards, or any other home improvement stores around you.
