1 - 4 of 4 Posts
As older XTR seem to be de riguer for SSing, I thought I might pick myself up a pair, were I to find them cheap...my question is, although they appear nearing identical, how did the cranks evolve from 950 to 951 to 952. Are the 952s much different/better/more desirable than the 950s?
Good question. Without having my handy reference binders, the main differences are in the chainrings. M950 was 8-speed evolving to the M952 9-speed compatible rings. Arms are probably virtually unchanged.
Do It Yourself
Fuctionally, Mike is correct. The M950 and M951 were eight speed and M952 had nine speed rings. The M950 arms have a slightly different shape (wider) than the later models but the M951 and M952 arms are identical. The design change is minor but the M951 and M952 are probably a bit stronger/stiffer.
1 - 4 of 4 Posts
