Yes, everyone will have input on this.Danp87 said:
Now, if you can, quickly delete your post before the avalanche of worms from the giant can of worms you just opened knocks you down and kills you.
Oh, and go use the search tools.
Yes, everyone will have input on this.Danp87 said:Does anyone have any input on for the pros and cons of each?
Hmm, I use clipless and rarely does the bike follow me down. I can unclip just about as fast as stepping off platforms. I've seen a couple damn good riders using staps too.mstguide said:If you want your bike to follow you to the ground when you fall clip in, if you want the bike away from you when you fall use platform. As for straps well, is just a cheaper form of taking the bike down with you. Clipless are a version of clip in that has a little different tech. but it will follow you to the ground when you fall.
Platform pedals are clipless + Clipless pedals require that you "clip in" = Platform pedals require that you "clip in".JonathanGennick said:Two key things to remember:
* Platform pedals are clipless
* Clipless pedals require that you "clip in"
platform pedals are platform pedalsJonathanGennick said:Two key things to remember:
