Hey Bug,
What length stem are you running? If you are doing longer rides, than a fairly long stem is a good idea (70-90mm). Aything over 100mm tends to make you feel a little less confident while riding generally as it puts you over the front wheel more.)
Also, you should try different bar height if you have enough stearer left on the forks to use some spacers under the stem.
Also, it might be worth experimentling with saddle position by adjusting where the rails are clamped. A sore lower back tends to mean either that the TT is slightly on the short side, so maube try moving the saddle back a couple of cm and see how that feels.
I would try a few different options of stem length (maybe try swapping with a couple of mates), saddle position and stack height and see if you can find a more comfortable fit.
It will be worth putting a bit of time into finding the right setup, as you will enjoy riding so much more when you are not worrying about back pain. I really hope you find a good solution.
Thanks,
Keith
Thanks,
Keith
