1 - 4 of 4 Posts
carpe mañana
hopster said:
Does anyone know where I can get an exploded diagram of a Fox Talas fork damper?
Thanks in advance.
The Talas damper is identical to the Float and Vanilla (the Vanilla has a coil added, but functionally it is the same).
I'm not sure if that helps, but if you'll look under Fox's service guide, you may find it. What's your exact question? What are you trying to do?
_MK
Discussion Starter · #3 ·
I am investigating this for a friend.
Specifically what has happened is that the rebound appears to be damaged. It is either fully open or so slow that it takes 10 mins to return all with a 1/4 turn of the dial.
Any advice would be appreciated.
Could it be clogged with dirty oil?
Or, did you already change the oil and now it's not working?
1 - 4 of 4 Posts
