A conversion device by Problem Solvers used to be available (still may be). It was available from Quality Bicycle Products through your local bike shop. It replaced the v-brake noodle and converted the pull ratio so non-v-brake levers worked perfectly with linear-pull brakes. As a bonus, they also alleviated some of the cable drag. These work excellent if they are still available.wv_bob said:I have discovered a forgotten set of Dia-Compe SS-5 canti levers here, and wondered if they are usable with V-brakes? If not, what is the expected result, unexpected brake lockup, or what?
Not enough cable pull.wv_bob said:I have discovered a forgotten set of Dia-Compe SS-5 canti levers here, and wondered if they are usable with V-brakes? If not, what is the expected result, unexpected brake lockup, or what?
I've got a pair of Avid Speed Dial 2.0 levers from about 1995 which I've used on several builds including linear pull brake bikes and currently doing duty on a 29"er with Avid BB-7 mechanical discs. With the dial maxed out, I have plenty of cable pull and these were made for cantis. Plus, they have red ano levers! :thumbsup:DeeEight said:16mm of cable pull = not enough cable pull. The absolute minimum for V's is 19mm (which is what the V-chipped Avid Ultimate levers got at the maximum leverage setting) which few cantilever era levers actually had. The only ones that immediately come to mind that met or exceeded that were things like the Tektro CNC levers I'm fond of (19mm), the old Shimano Deore/Deore XT SLR 2-finger levers (22mm), DiaCompe MX-99s (20mm), and that's about all I can think of other than the aforementioned V-chipped Avid Ultimates. Most other levers fell into the 13 to 17mm range and thus just didn't have enough pull to do the job.
yep, those'll work, i've got a couple in the parts box. Great levers aside from the bit o' slop/flop that always seems to work into them! The SD 2.0L/3.0's work a bit better with v-brakes.Guitar Ted said:I've got a pair of Avid Speed Dial 2.0 levers from about 1995 which I've used on several builds including linear pull brake bikes and currently doing duty on a 29"er with Avid BB-7 mechanical discs. With the dial maxed out, I have plenty of cable pull and these were made for cantis. Plus, they have red ano levers! :thumbsup:
