A friend of mine needed a DHX for his Stinky . I couldn’t find a Stinky size DHX for him over here . Those who know me know why !!
But I found a 9.5” DHX 4.0 for him from a Glory Dh frame. I Managed to resize it .
But want to know the mechanical faults it may cause.
I opened the Air cap also the bleeding port on the IFP ( only Fox DHX’s have this port) Or at least I havnt saw any on others ! Then pushed the shaft an inch in. and let fluid come out .
So now I had a Shock with 8.5” eye to eye and no air in the fluid system also the IFP position wasn’t changed . But its shaft was an inch in . That means When ( on the Stinky frame ) fully extended it was an inch through its travel ‘had some fluid behind the damper assembly .
I know it wouldnt bottom on that frame as its original travel is 3.35 “ and the Stinky’s own has 2.5” so my one inch shortening would be fulfilled by the extra travel.
Any other faults that I may havnt thought of ?
