Is everyone running their DHX with the air valve pointing down? While I had the shock off to replace the 400lb stock spring (who uses a 400lb spring?) I decided to try mounting it "upside down". It makes the air valve much easier to get to but put the PP adj at the bottom. Not a big deal for me as previously I set the PP once and didn't change it but usually check the air every couple of rides. Everything cleared the frame fine in this orientation.
Is there a reason I shouldn't run the shock like this?
