Have a Heckler 4(03-07) with a PUSH tuned RP3 on it currently.
I am 6'3" with a XL frame and approx. 230lbs
From looking at the other forums it seems that a coil and Hecklers make for a good combination.
My current problems arise from the trade off of small bump compliance to mid-stroke blow through.(To get good small bump comp. I have to run lower psi, but this then compromise mid stroke performance)
I understand that this is an inherited issue with the falling shock rate of the frame design. I am wondering if the DHX 5.0 or RC4 can be set up appropriately to address this.
Which would perform better for this frame?
Can these shocks be set up progressively enough to reduce mid-stroke wallow without compromising small bump compliance?
Or should I just cut my losses and move on to a Butcher, Nomad or Enduro?
Thanks for the Help
PS anyone have much experience tuning the above mentioned shocks or FOX 36 dampers (adjusting shim stacks etc) It appears to me that this is very common place in the Moto world yet almost unheard of in MTB(except for PUSH ind. TFT, Avalanche and a few others)
Thanks for the Help
