Interesting. I had a very low use DHX coil that was working perfectly on a Bullit when I pulled it off. It didn't sit as long as yours, maybe only a month. In fact it had a relatively fresh service on it from Fox because of the original DHX "clunk" in the piggyback that occured when the shock was new. I had a pair of these shocks in different lengths and never warmed up to the slight mid-stoke harshness that I felt they produced in the Bullit. keen, who posts here frequently bought one of these shocks and said the shock immediately had a malfunction that may have been similar to yours...maybe he can post to compare symptoms.
I cannot imagine how a relatively short period of inactivity would cause a malfunction...maybe on a shock left for an extremely long period of time out in the elements perhaps. I certainly don't have any insight on how or why a shock might do this. Darren would probably be a good source. One would think this was as much coincidence as anything, but maybe not.
wmbarace, how old is your DHX and about how much use do you think the shock has on it? That one of mine had very little use and even a fresh service, but I don't know if there's any real comparison here. It was working fine...and then wasn't working fine after sitting. It would be interesting to know if inactivity affects a shock to any degree, and if so, how long and what kind of storage helps or hurts a shock. I've experienced "negelcted shock" syndrome in an old Cane Creek AD10, but geez, in that case the shock had been sitting in a hot/cold storage building for a matter of years after being used for years before that, so I wasn't shocked...pun intended.
