Doesn't it have Pro Predal as a compression damper? Perhaps is the lack of smooth rebound that the DHX-Air suffers from? Not the biggest suspension guru...
I believe that it does have some form of propedal, but that is not the same as compression damping.chad1433 said:Doesn't it have Pro Predal as a compression damper? Perhaps is the lack of smooth rebound that the DHX-Air suffers from? Not the biggest suspension guru...
today? You sure seem to have a lot of free time... hey maybe we should just call it a day and go ride! Ha, ha..... Are you talking smack about the DHX air? I could comment if I owned one but my RP3 is working just fine.Blue Shorts said:I believe that it does have some form of propedal, but that is not the same as compression damping.
Actually propedal is a type of slow speed compression damping.Blue Shorts said:I believe that it does have some form of propedal, but that is not the same as compression damping.
So you are running away with unverified heresay and second hand info and starting a thread just to talk smack? Man, you must be bored.Blue Shorts said:I've recently heard that the DHX air is not a very sophisticated shock. I've heard that it has virtually no compression damping and is basically just an undamped air spring on compression.
I haven't had this verified yet...
Shims are what are called "valve quality" surfaces and are rather expensive. Being them steel, a couple grams they do weigh... you don't put them in a shock if you're not going to use them.The Squeaky Wheel said:I just clarified the innards
If you were to take apart a DHX air you would indeed find shims on both the rebound & compression part of the piston.
But while the compression shims are there, they don't function on the DHX-air like they do with other Fox shocks and the compression damping really takes place at the PP & BV.
Doesn't make much sense... But if Darren says so...The Squeaky Wheel said:in the DHX air they serve as a non-return circuit.
And that has completely exhausted my knowledge base at this point![]()
