You can remove that knob, there should be some small set screws holding it in. Otherwise you can stick a small allen wrench in the holes of the knob and use that as leverage to move the knob, just be careful not to break your allen.
That's the 'Bottom-Out' adjuster, he's asking about the ProPedal adjustment. Haven't heard of the ProPedal getting stuck. Call Fox and see what they suggest.Whoaohohohoh said:You can remove that knob, there should be some small set screws holding it in. Otherwise you can stick a small allen wrench in the holes of the knob and use that as leverage to move the knob, just be careful not to break your allen.
