so i'm getting a transition dirtbag and i'm trying to decide which shock to get. Dhx 5 or a Roco Tst R. What do you guys think and why?
I had a Dirtbag with the DHX... real plush, lots of adjustments and dependable. I don't have expereince with the Roco. I am looking at the Cane Creek Double Barrel for my Uzzi at this point. My $.02.PLURPIMPIN said:so i'm getting a transition dirtbag and i'm trying to decide which shock to get. Dhx 5 or a Roco Tst R. What do you guys think and why?
The TST has an adjustable platform. It should climb pretty well.gline said:Roco, unless you are going uphill, then go DHX. But if only down, then roco
That pretty much sums it up. I have both a roco TST and an RC on different bikes, on one bike I rode the roco back to back with a DHX-C, same spring, same bike and same trails. The spring felt #100lb lighter on the roco, cushy, yet with the TST adjustment you can go all the way to lock-out.Alloy said:Get the TST... I've been riding one for a few months and it is a step above the DHX. It's not a huge improvement, but you will notice slightly better traction and a little more stability through the bumps.
Plus the TST has a switch that drastically increases compression dampening. Flick it all the way over and it will climb much better than the DHX and have more bottom out resistance than you'll ever be able to use... turn it completely off and it feels like a moto shock.. I use mine with the switch half way on for racing.
I have an M3 on order with the DHX... what is it about that fox you don't like and why would the Roco be any better? Just currious.SHIVER ME TIMBERS said:I am getting the TSt ......not really liking the Fox
