1 - 20 of 24 Posts
truth seeker
I'm thinking of mounting a Fox DHX 5 coil rear shock (7.875 x 2.25) on my 2003 ID. Any fit issues? Are there other Id riders with experience riding the Fox coil rear shock?
Amphibious Technologies
You may have issues with the reservoir hitting the downtube. I would go for an Avy Chubbie instead of a DHX (more reservoir clearance).
Premium Member
wouldnt mess with fitting it to an ID, not a good thing. Go with an RP3.
truth seeker
Discussion Starter · #5 ·
Why is it not a good thing? I've ridden the DHX 5, and it is one sweet shock. I don't want an air shock, so for me, the options are keep the Romic I have or upgrade to the DHX 5 or a Fox Vanilla RC.
The Moment geometry seems pretty close to that of the Id and I thought the DHX 5 would likely fit the Id (i.e., the reservoir would not hit the down tube) since the DHX 5 works on the Moment. What am I missing?
Brass Nipples!
I can't remember for sure, but I think Ellsworth said the shock doesn't fit an Id due to clearance problems and the Moment was the first bike to have its mount designed specifically to fit. I do like the shock a lot, but Maybe Whafe's saying the mess isn't a good thing.
I think the best answer would come from writing or calling Ellsworth directly. Maybe pecusick can answer if he reads this.
Time is not a road.
How about Manitou 3-way? There's no res. to get in the way, yet you get some of the options of the DHX. I imagine you'd have the same problems with the RC as you would with a DHX. Doesn't Fox make a shock with a remote res? I know 5th Element does. Maybe that'd be an option, too.
truth seeker
Discussion Starter · #9 ·
Actually, an Ellsworth rep told me in an email that a Vanilla RC will work.
I'd prefer the DHX 5. If that doesn't fit, I may order an Avy or try to find a 7.875 x 2.25 Vanilla RC.
Time is not a road.
I wasn't too familiar with the Avy, but it seems to be getting a lot of buzz, especially on the Turner boards. For you, it looks like the ticket:
• Floating piston compact reservoir design fits space limited frames
It just depends on your budget(that Ti spring is sweet!).
Or you may want to check out the
CCDB. It might just fit...
truth seeker
Discussion Starter · #12 ·
Well, I *guarantee* that the DHX 5.0 coil will not fit on the ID - the reservoir will indeed strike the downtube at full compression. That is the bad news. The good news is that I have an Avy Chubie on order. :D
Anyone want to buy a practically new DHX 5.0 coil (7.875 x 2.25)???? :)
Reptile said:
Well, I *guarantee* that the DHX 5.0 coil will not fit on the ID - the reservoir will indeed strike the downtube at full compression. Anyone want to buy a practically new DHX 5.0 coil (7.875 x 2.25)???? :)
Am I missing something here? Didn't we all indicate it will not fit on the Id :confused:
truth seeker
Discussion Starter · #14 ·
I guess I missed the unanimity of opinion to which you refer. You said that I "may have issues with the reservoir hitting the downtube"; Lucky7 gave it the thumbs down from firsthand experience (should have listened to him); Whafe said "wouldn't mess with fitting it to the Id"; and Bob the Wheelbuilder recommended contact with Ellsworth.
Well, I take everything I read on these boards with a big grain of salt, although clearly there are some regulars - and you may well be among them - whose advice is actually worth something. I bought a shock (one in excellent condition that I knew would fit a friend's bike if it didn't fit mine) after receiving this well informed missive from one Tony Ellsworth, in response to my inquiry regarding a similar size shock with a large reservoir (DHX air):
[Tony Ellsworth] The DHX AIR will fit it-I'm pretty sure… Piggy Back on the upper side, just make sure it will compress fully without contacting the down tube.
Maybe Ellsworth is not the best source for reliable information about Ellsworth... :(
Ah-huh! That's what I missed :D
Brass Nipples!
Looks like my advice wasn't worth much in this case. Sorry :eek:
Vanilla RC fit
OnTheMoment said:
My Id had a Vanilla RC and it worked great.
I'm positive that someone posted a pic of a small, red-ano ID with a Vanilla RC here in the Ellsworth forum. I saw this pic after I was told by someone handling my case at Ellsworth that the Vanilla RC wouldn't fit the size small 2004 ID that I was getting, due to reservoir/down tube interference.
My warranty situation took a while to straighten out, including them sending me the wrong size frame/wrong shock on the first try. Ever since I saw the pic, I've wondered if I was just being hurried along when they said that I would have to go with the Romic. Obviously they had the small frame/Romic combo readily available to ship immediately.
Another (admittedly) rather cynical suspicion on my part was that I was being "inventory clearanced" in the sense that the employees were aware by that time that the ID was being discontinued, and they were done with ordering Vanilla RC's from Fox. As it turns out I'm now a fan of the Romic, but hmmm....
Just out of curiosity, can anyone out there confirm whether or not a 7.875 x 2.25 Vanillla RC Propedal would fit a small 2004 ID? I was initially leaning towards that shock because there is always the PUSH option if the stock valving was not to my liking.
I've done it (small Id). Yes, it fits without any clearance issues. PUSH'd RC works great on the Id.
1 - 20 of 24 Posts
