I'd run that combo the other way round, i.e. TK front and DHR2 rear. When you see Greg Minaar running a DHR2 on the front the tread has been modified to give better directional stability by his team mechanics.Ok so if I ran a 2.4 tk (60-59) in the rear with a dhr 2 in front (58mm) would it be a good fit or would the back be jacked up higher(too high)?
Hmm...i've been on a full season of it up front (as recommended by the shop I bought it at)with a spesh butcher control on the back (would not recommend). I doubt I could get the TK on the 819 I have in the front. Maybe I'll try a dhf or a baron on the front.I'd run that combo the other way round, i.e. TK front and DHR2 rear. When you see Greg Minaar running a DHR2 on the front the tread has been modified to give better directional stability by his team mechanics.
