uvsh said:
this frame looks sweet but i couldn't find much information about it
has anyone ridden this bike and can advice about it? is there any professional review you can refer me to? how aggressive can it be comparing let's say to a SC heckler? i'm not sure what kind of fork can be used on this frame, is it limited to 130mm?
thanks!!!
I think the Guzzler/Magma would more comparable to the Heckler than the Remix. The Remix has a fairly long wheel base and a slack ha which make it a very capable bike on technical trails and will help with stability when descending a trail. With suspension up to 150mm, the Remix will have no problems on aggressive technical terrain.
The main difference is that the frame on the Remix has been lightened and does not have the gussets and general beefiness of the Heckler or Guzzler. I would not be airborne that much on the Remix for these reasons. I am sure it can handle the smaller jumps and bumps found on most trails though. The maximum tire clearance on the Remix is smaller than the Heckler also, which makes a difference on freeride terrain. The 130mm fork is more than likely on the Remix because it is a lighter frame also. This is not to say a Pike or AM1 couldn't be on it instead. I really don't know.
I used to have a Heckler and it takes it up a notch from the Remix, as it can be used for light freeriding. I have not been on a Remix, but it would probably have a slight edge in technical climbing over the Heckler because of the Horst Link.
You might want to page
ErrAzib and ask him some questions, as he has a Remix and is on this forum sometimes.
Good luck with your search.
