Deus vs Turbine + Wood
865 Views 9 Replies 6 Participants Last post by  CrashTheDOG
I am building up a 1x1, and need to choose some cranks. The Deus cranks look very promising, but I was also thinking of a more traditional square setup like some Turbine Lps with a steel Phil Wood bb. Cost would be about the same for both setups. What would you choose and why?
1 - 10 of 10 Posts
Absolute ease to take Deus off and on for cleaning and maintenance and adjustable chainline makes it a no-brainer. Go for the new and improved. :D
Check the reviews on the Deus here....
Not exactly glowing are they? Seems like the majority of the 8 users in the review section had continual probs with the drive side arm coming loose, some even after warranty replacement. From the looks of it, niether Shimano or Race Face has their cranks with ext bearings dialed yet. Larger diameter spindle and big outboard bearing is a good concept, after crappy life spans of the BB's in the isis and octalink splined setups squeezing too much into the BB shell. I'm vote for the square taper and Phil BB. But then, at a buck sixty five I'm not a big boy and the extra stiffness from bigger splined axles over square taper wasn't exactly a night and day difference for me.
Two reviews from "Jason", who does not know how to install it, and another negative from a guy who needs a mechanic to install it (and we know how good they are at the LBS) does not exactly constitute a problem.
Everybody I know and myself had nothing but excellent performance from it. But, yes, I would not mind using new XTR BB instead - nice that they are interchangable.
I will not touch square taper ever again. :D
Just for questions, why not? I've never had a problem with a square-taper crankset, and there is no better BB than Phil Wood. Nothing else comes close.
Splined BBs are a solution in search of a problem. Oh wait, the problem to which they are an ideal solution is people not buying their bottom brackets from the same companies they buy their cranks from.
Integration sucks.
--Shannon
I agree 100%
Phil Wood BB's are awesome.
I will go one step further and say a nice cup and cone BB...Dura-Ace or Campy is even nicer...spins much smother and will last forever as well.
Integration sucks.
--Shannon
Just for the answer. It takes 10 seconds to take it apart and change crankset (I use different ones for different riding) with perfect fit every time and no wear. Perfect alignment everytime from the first time. Adjustable chainline and spacing. They are stiffer - by far - very noticable for 200lb me. You did not have problems? Well - I did not have problems with my old 40lb cruiser, not a single one. Should I ride and race it?
I use BB and cranks from different manufacturers with great success. Your sarcasm is absolutely out of place. For Deus, you can use Shimano BB, just fine. BB is twice cheaper then Phil Wood BB. ISIS was not a very good standard from the technical point of view - but still better then square taper.
Integration, done right, works just fine. Do you object to 20 and 24mm front hubs as well? Should we use drum brake hubs like you do? Sorry - nostalgia has many uses, but a good source for technical advice it ain't.
Hmmm.. Let's see here. Crankset removal: Square taper: grab appropriate Park crank puller, pull crank. Splined: Same thing. Verdict: Tie.
Adjustable chainline and spacing? This is a feature of the BB design, not the spindle. Phil BBs have adjustable chainline and are square taper, Shimano's don't and are splined. Verdict: Tie.
Stiffer by far? Wrong. Simply wrong, and I defy anyone to pick, blind, which of any of several crank / BB interfaces is "stiffer". This is ignoring the question of whether or not stiffness is an importnat criterion for judging your BB. Here's a hint: It isn't. I am aware of no experiments which prove that flex in any part of a bicycle, except tires, dissipates measurable pedalling energy. And I've looked. All the marketing in the world won't change the laws of physics. Verdict: Tie, due to lack of important differences.
Of course integration works fine, that's why it exists. But so does non-integration, and allows for greater choice for the consumer. Take it for truth, Shimano didn't come out with Octalink because there were significant problems with the old standard. There weren't, and aren't. You can find well-executed and poorly-executed examples of each. Shimano was tired of companies not spec'ing their cranksets on otherwise all-Shimano bikes, so they came out with Octalink. Now, a new product that destroys inter-operability with existing parts is a tough sell, so how de we do it? Aha... 12.0193% stiffer than last year's model!! Which was already stiff enough, since they weren't bending at appreciable rates, but everybody knows that "stiffer is better", since we'ev been seeling that line for 20 years. Then set the licensing fees for the "new" idea so high that none of your competitors can afford them.
Voila, Shimano's share of the high-end crankset market zooms to levels not seen since the early 1990s. In response to this, the other crank makers came out with a slightly different version of the same idea, and gave it away for free. Thus was born ISIS, and endless debates about whcih of two almost identical systems is "better". In response to which, Shimano lowered the prices for licensing of the Octalink design, and third-party crank makers could go that route if they wanted to. I fail to see how riders benefit from any of this.
Drum brake hubs? Yep, I've got them on two bikes. One is my tandem. The Arai drum brake is still the ONLY safe choice for a continously-on "drag" brake for a tandem. Continuous braking on a 400+ pound bike will warp any disc rotor made, and will also heat up and expand the fluid in a hydraulic disc brake, instantly locking the rear wheel. This is bad. The other drum-brake hub is on my singlespeed. It just to happens that drum brakes use the same thread as freewheels, so with a quick re-space and re-dish of my spare set of tandem wheels, I got a sweet, high-flange 40-spoke wheelset for free.
Sorry, but it's not Luddism or retro-fetishism. That which works, still works. Most of the "improvements" in components have come about because of the need to generate sales in a flat market. In other words, "How do we sell new stuff to the same people, who already have stuff that works great?" The right question should be, "How do we bring new people into this activity, so that we can have new customers for our stuff?", but that's harder than preaching to the choir, so almost nobody bothers.
--Shannon
Wrong. Do installation and removal several times. Pay attention to installation, not removal. Try swapping two crank sets - I swap 2x9 and 3x9 ocassionally. Square taper is not anywhere close to the convinience of splined, and especially outboard BB interface. You are flat out wrong. Not that I care - but please, spare other people.
Phil BB adjustability is nowhere near the convinience of the Deus. I know - I did use it. Wrong again.
You are either a 90lb weakling, or just do not know what you are talking about. I can easily tell a typical difference, on a variety of bikes.
It is not about energy dissipation. It is about ride quality.
It does work - but not nearly as good. As I said, my old bikes still work, but are not nearly as good. I do not care about "bringing new people". I care about personal convinience and satisfaction. Same for the original poster. He has two choices - for the same price. Your suggestion about "generating sales" is preposterous. What does not work - does not stay, plenty of examples of that. Splined crank interface is here to stay, that why ISIS happened, and outboard BB happened. They are convinient, reliable, as cheap, or potentially cheaper, and work just fine.
I suggest the original poster gets the better choice, no matter if the old style still works or not.
I'm having some resistance/binding with the Deus cranks I installed. Any hints or suggestions that I need to be aware of in addition to the instructions would be greatly appreciated.
1 - 10 of 10 Posts
