Speaking of +10% it's like a 29x2.0 wheel compared to 29x2.2
I think it also make sense given a taller rider is also heavier and needs more cushion. The fork in the 1st picture is 420ac, and yes there are forks in the 465-470 range (=+10%).
If we really want to go fussy a taller tire brings also a higher BB, so you might want to increase the BBdrop as well.....
But I don't want to go too deep into details, I just wonder if there's a reason for same CS and (much) different angles other than cost cutting.
that's my point, it doesn't make sense to me
When people get taller, generally, they have longer limbs and shorter torso. This can be described as "Ape Index" or (Wingspan from tip of finger to tip of finger) / (Height). An Ape index of "1" means that your arm span equals your height.
When you examine people at the extreme ends of the spectrum the pattern emerges where short people have an Ape Index of <1 and tall people have an Index of >1.
All to say that as you get taller (or shorter) frame sizes and configurations that are mass produced follow these trends because of sales volumes.
If your body configuration is outside of these parameters then you could be out of luck finding something off the shelf.
Add to this that femurs tend to proportionally longer than the tibia/fibia (same for the Humerus vs Radius/Ulna) and there are all kinds of medical conditions that can lead to growth in different proportions such as Marfans syndrome (Abe Lincoln) or various pituitary tumors.
Regarding frame design- I have built frames for short people and tall people (6'10"). The approach I always take is to begin with the Lemond system of measuring the inseam for obtaining the "Frame Size" and saddle height.
Using that frame size, Ill set my Serotta fit bike to a "square" size ie the TT is the same as the ST or "Frame Size".
This is by no means a Universal system. It is a data point and a starting point to get a person pedaling. Then comes all kinds of adjustments depending on the type of bike, rider dimensions etc etc etc.
The first thing I always do is set the saddle position relative to the BB. Different for every rider, purpose, bicycle type etc.
For you, you may have long femurs. On a road bike, this will put your seat tube at a smaller angle ie ''slacker''. This is because the power stroke radius is longer (your position over the pedal at 90 degrees). That in turn would shorten the "reach" (horizontal BB center to HT center).
These examples are not definitive, I am using them to illustrate how frame designers may approach the design of each frame size. Its not as simple as expanding everything by 10% or whatever.
A lot of this stuff was worked out by the Italians a long time ago, at least for road type frames. I am guessing that a lot of people in the industry just copy off of each other without doing a lot of targeted research themselves.
Some advice that may help you design your frame or at least give you a better understanding of what you might need...
Look up Greg Lemond's frame size formula. It is described in his first book and widely available on the internet. There is a story about his TDF coach that raised his seat and brought him to victory. He describes the formula his coach used to size him and his reaction to that advice.
This info is outdated today but it is a beginning and its simple to understand. From there, get yourself on BikeCad...the free version, and play around with it. there are 100 things that all change when you change one thing. As you work with it you will get better at predicting and understanding what is going on.
I hope that helps. Feel free to PM me with a question or if you are in the Bay Area...I can size you on my Serotta.
