I am new to YETI and about to build up my 575. I am a bit confused about the derailluer cables. First, what type(s) do you recommend? Second, do you have to use fully enclosed cable housings? Any and all input will be greatly appreciated.
1) Why would you not want to run full housing?pono39 said:Do I have to use full cable housings? Everything I read says that I have to use a completely sealed system. Is this accurate?
If you ride in wet/muddy conditions there is a real benefit to full housing. Otherwise just having the cable fully routed in housing (in theory) provides crisper shifting and is absolutely necessary with 575 just b/c of how it's run to the rear.pono39 said:Perfect - thanks for the info. Never used full cable housing kits before. My MOJO had all cables run along the top tube and upper part of seat stays. Just need to adapt. Thanks again!
You can take a piece of string and run it like the housing, then measure...to be sure of the length.pono39 said:Thanks for all the info. One last one - do I need to get the derailleur housing in an 'extra long' version or is standard ok?
