If you don't change the crank, you can still run a medium cage.
See the sticky near the top of the pageProstreet513 said:So right now I am running an all Shimano XT drivetrain. I an using the Med Cage XT rear with an 11-34 cassette and 9 speed shifters. I am thinking about going to Sram X9 or X0. My question is since I am only running the small and medium rings on my crank if I go to sram should I also use an med cage and should I do 11-32 or 11-34?
Have run 2x9 with SRAM since 2004, both work but mid-cage works a little better.Prostreet513 said:So right now I am running an all Shimano XT drivetrain. I an using the Med Cage XT rear with an 11-34 cassette and 9 speed shifters. I am thinking about going to Sram X9 or X0. My question is since I am only running the small and medium rings on my crank if I go to sram should I also use an med cage and should I do 11-32 or 11-34?
I thought that as well and I tried a bike out with sram x7 and then one with x9 and the shifting is so much better. I was amazedC.M.S said:Why I must ask ? XT RDs are one of the best out there.
