1 - 4 of 4 Posts
There's a lot of up and down play in my Shimano Deore 10 speed shifter. It feels like springs or whatever is holding the bottom plate together is quite loose. Anyone run into this and know how to fix it?
Discussion Starter · #3 ·
Check the screw on the bottom ensuring it is tight.
Or look at the bottom ensuring the housing appears to be intact and properly seated.
Thanks, I had checked the screw and it's tight. The housing seems off though. I wonder if there's a trick to it. Not sure if I mess with it too much if I'll be able to put it back together.
1 - 4 of 4 Posts
