Doin' TIG, brazing, Mig? What type of welding?
Henry James sells most of the stuff you need to get started with lugged brazing. Talk to Hank.
I found that brazing is the easy part. Cutting, filing, building a jig, getting everything aligned and fitted well, etc... are what's difficult.
I started with a practice "kit" that has lugs and some tubing to practice with.
You can also get tubing and supplies from Aircraft Spruce Supply.
http://www.aircraftspruce.com/
They also have carbon fiber lay-up supplies at Aircraft Spruce.
Most of the stuff from airplane welding cross over into bikes... a.k.a Wright Brothers.
Oh yeah, try Yamaguchi. He used to teach also. Or maybe Eric Barr at Ground-up Cycles.
UT
UT
