1 - 20 of 20 Posts
I'm thinking about buying a used DJ bike, but the frame has a dent in it. Should I be worried about this dent, or is it no big deal? It's a steel frame.
Here's the pic of the dent...I hope the pic turns out.
how old is that dj bike? i haven't seen a kona with a headtube gusset like that before... :confused:
but back on topic, i useually stay away from bikes with dents.... but that just me.
so do i
thats either an 02 or 03,(i think there was a scab in 03) kona
scabs are also one of their lower end dj bikes
high school loser
scabrider had one. its 02 i think. really really solid frame. he had a small dent the same spot for awile and nothing ever happened so its probley safe.
Discussion Starter · #6 ·
It's an '02. I'll probably pass on it. 3 yr. old frame that's probably been thrashed quite a bit. I'm sure it wouldn't be long before a nut-buster occurred.
Discussion Starter · #11 ·
Felpur said:
That's not a very good deal for a damaged product, I'd stay away unless it was uber cheap.... for that same price range you could get a new frame ie Azonic steelhead is cheap or Mt cycle rumble to name a couple... :rolleyes:
That's what I wanted to do...buy a Steelhead and build it up. My problem is I don't have any parts to build it up with. By the time I bought everything I needed, I'd be out around $1,000. My budget for a DJ is $300. I won't let myself spend more than that.
dude, its a complete bike sith shiver sc and sh!t
RuNDmC1087 said:
I think its even older, like a 98 or 99, the really old ones with the bending seat tube
anyhow im not sure about teh dent, but its probabally best to stay away from buying that frame/
.WestCoastHucker. said:
steel is real...
that dent isn't sh!t......
I have one, got a dent a little smaller in about the same place, I think wch is right, that dent shouldn't be a big deal on a steel frame.
or if you like that frame, you could get it for cheaper than I've seen steelheads going for.
http://wheelworld.com/site/itemdetails.cfm?ID=2188&Catalog=39&sort=Price
here's mine.
complete, my bad, that is a good deal then.. I thought just frame
damm...need to stop smoking my breakfast
Cynical Bystander
steel is real...
Exactly. Those old Konas are all steel and will put up with lots of ****. Any steel frame will. Those are just battlescars :D I used to have a On-One Gimp and I bought it used with several dents in it and while I didnt do much on it it held up fine to my 210# ass on plenty of things. :cool:
pwn3rator
yeah, mine has a dent in th' same spot but it has'nt caused me any troulble, i wouldn't buy it anyway cause it has i dent and something might happen...
Discussion Starter · #19 ·
Thanks for all the responses. I'm not gonna buy it. I don't mind buying used stuff, but not used stuff with dents in it. Plus, I think it might be too small for my 6'1" height.
pwn3rator
i got an '02 in the end of '03 for $400.00, i would just look around for a new one, the rigid fork also helps you to become a more flowy rider instead of just going right through stuff like you're on a demo 9...
1 - 20 of 20 Posts
