I need to bounce something off everyone.
I own a 2000 Ellsworth Dare. Last year I sheared off a set of Cane Creek S2's when flying down a rough trail in Jamaica. Yea, it is made for light weight and I should not have been using it, but it was what I had and I had not thought of myself as being too tough on equipment. Anyways, I jumped on the phone and ordered a set of Pig DH's, when they came I noticed that the frame was reamed for a regular headset and not a deep headset. Since I did not want to hang the bike for a couple of months and did not trust any of the locals to work on the frame, I decided to cut off a piece of the cups, making it a non deep cup. It installed without any problems and have been riding it till last week. I started hearing a slight creak and put some spray oil at the headtube/headset interface to to make sure. Sure enough it stopped, which leads me to believe that it is moving slightly in the headtube.
I ordered a set of Race Face Diabolus and brought it to the local bike shop in Tampa ( moved here a few months ago). Mechanic takes alook and said that I need to buy a regular set since the Diabolus is too deep. Says he will try and press it in anyways, I tell him to first measure the depth of the headset and compare it to how deep the headtube was reamed. He did not and presses it in anyways, of course it does not go in all the way and I figure that my chance of returning it is now screwed.
My choices are.....:
1. Machine a bit off of the end of the headset so that it fits the headtube. About 1/8".
2. Have the headtube reamed a bit deeper.
3. Grind off a bit of the headset so that it does not sit so deep.
4. Change the headset to a regular depth type.
Before you decide, let me tell you my thoughts:
A. I do not want to go back to a regular depth headset because if the headtube is slightly ovalized, the new headset will not help.
B. If I grind the headset lower, it will accomplish the same thing as above. I will save the $ by reusing the same headset.
C. Between grinding down the headset or reaming out the headtube a bit more, I prefer reaming out the headtube deeper. The problem with this is that most bike shops will not have the proper tools. Do you think a machine shop can do the job?? If they cut the headtube more that necessary I am screwed. I would much rather they screw up a headset than the frame.
Ideas anyone??
Ideas anyone??
