1 - 4 of 4 Posts
No longer 26
What do y'all think?
Could a crankset that was designed specifically to be a double mtb crank be made lighter than conversions of current crank designs? Maybe something that would use the current 4 bolt small and mid ring bolt patterns. Designed to run anywhere from 22/32 to 28/42. Chainline moved out a few mm so both rings could use full cassette. Maybe a bit lower q factor.
Do you think there would be a market for that? I have a bit of an idea how it might be made a bit lighter than current crank but not sure where to go next with it. Not sure if it would be worth the research though.
Ta'
Greg
No longer 26
Discussion Starter · #3 ·
Fredrik Larsson said:
Something like Middleburn RS8 Duo?
Claimed weight for 29t+42t ISIS is 522g (BB not included)
Similar but using the standard 4 bolt pattern that we have all grown to know and love:confused:
Look at the Middleburn site and check out their spiders. I think the thing to do is CNC machine a spider that accepts double 4 bolt rings and sets the chainline correctly for a 108mm BB.
That is probably more doable. You check out the functionality for cheap and test the market.
1 - 4 of 4 Posts
