Anyone have an experience with Dean's version of adjustable dropouts? Are they better than an EBB?
There's an echo in hereCPATCRASH said:Thoes are Paragon dropouts. I have them on my SS and have had zero problems. Check it out. http://www.paragonmachineworks.com/
EBB results in a nice clean look, without the complicated dropout design employed by Paragon.cazloco said:Mods work great and you don't have to carry an extra tool in your pack as with some EBBs.
Also with the EBB, the frame design may limit rear tire size.
Mods with rim brakes don't work so well but with disc; the caliper slides with wheel.
Stock EBB frames weight more than those with mods.
my .02 cents
Caz
Actually, I think it looks OK :rockon:Sasquatch said:EBB results in a nice clean look, without the complicated dropout design employed by Paragon.![]()
Extra tool? I carry a 4mm allen. That's all I need. Looks like a small crescent wrench would be needed for the Pragon drops. Plus six bolts as opposed to two.cazloco said:Mods work great and you don't have to carry an extra tool in your pack as with some EBBs.
True, from what I've been told.cazloco said:Also with the EBB, the frame design may limit rear tire size.
If I was going canti's I'd probably just get horizontal drops. I do realize the brakes won't always line up, but it is the simplest way.cazloco said:Mods with rim brakes don't work so well but with disc; the caliper slides with wheel.
From Walt's blog:cazloco said:Stock EBB frames weight more than those with mods.
