Not too shabby! Definately looks worth the wait. I bet if you switched out to a non-poplock Reba you could fix your clearance issues?
Now go out and give it a good flogging.
OrBikbldr said:Ok complete build will be about 24 lbs. Without cable housing, but with a full chain without any links taken out and an uncut steerer tube the bike is 24.05 lbs on my digital scale. Everything was hung on the bike prior to weighing even though parts were or were not in the right spot.
I would send it back.
chruby99 said:The part that makes me want to send it back is the clearance, I was really specific about it. I just know that one good wreck and there will be a crease in the down tube. I gotta get that Ventana race that will space it out a bit so the fork won't hit. Hope they have them.OrBikbldr said:Ok complete build will be about 24 lbs. Without cable housing, but with a full chain without any links taken out and an uncut steerer tube the bike is 24.05 lbs on my digital scale. Everything was hung on the bike prior to weighing even though parts were or were not in the right spot.
Be sure not to cut the steer tube too short. You will need more length with the taller crown race.OrBikbldr said:The part that makes me want to send it back is the clearance, I was really specific about it. I just know that one good wreck and there will be a crease in the down tube. I gotta get that Ventana race that will space it out a bit so the fork won't hit. Hope they have them.
since you're only missing by a little i would just shave off some of that material from the forkOrBikbldr said:As posted in my other thread, there is a clearance issue that I have with the Reba. I need to get a Ventana made race for the King headset Here is a close up of the problem area. I more than a bit sore about it...
I thought about that, but what a pain, plus it will kill the resell value it is looks amateurish. I am hoping that the WB forks are sweet, if so I will be selling this Reba soon.b12yan88 said:since you're only missing by a little i would just shave off some of that material from the fork
file it.OrBikbldr said:I thought about that, but what a pain, plus it will kill the resell value it is looks amateurish.
