Upgrade your suspension or keep your suspension performing its best with an overhaul. Jenson USA has deals on new forks and shocks as well as all the oil, seals and upgrade kits you need. We've rounded up deals from Fox, RockShox, MRP, PUSH, DVO and Cane Creek. Click here for all of Jenson USA's suspension gear.
Related: Specialized Gear On Sale At Jenson USA - Save up to 50% off
FOX 36 FLOAT PERFORMANCE GRIP 27.5 2020 OE - Save 20%
1925589
The Fox 36 Float Performance fork is the economical version of one of the most advanced forks on the market. The performance version includes many of the same features as the Factory versions like the EVOL air spring for added plushness and Fox’s Grip damper. The Fox 36 Performance has a tapered steer tube for reliable and sturdy handling and comes with black anodized stanchions and magnesium lowers to save weight. FOX's Grip damper uses a three-position damper to offer high and low speed compression adjustment and rebound adjustment for precise control over changes in terrain. The Grip damper uses low friction seals and low viscosity damper oil for improved rebound performance and a patented air transfer port system with more linear spring curve to provide added plushness and more tunable bottom-out progression
Price: $909.00 $727.00
GET DEAL
ROCKSHOX CONVERTIBLE HIGH PRESSURE/HIGH VOLUME SHOCK PUMP - Save 23%
1925590
Whether you're riding on the trails or racing competitively, the pressure in your suspension and tires will have a significant impact on your performance. The RockShox Convertible Suspension Pump allows you to carry one pump for trailside flat fixes and to pump up your front and rear shock with incredible accuracy. Use the high volume mode and Presta adapter to inflate your tires and switch to the high-volume setting and Schrader value to dial in your suspension.
Price: $52.00 $39.95
GET DEAL
MANITOU MATTOC PRO 27.5 FORK - Save 10%
1925591
The Manitou Mattoc Pro is an aggressive all-mountain fork with 160mm of travel. The Pro model features the lightest weight chassis with taper wall legs and Manitou's patented hollow bore crown. Additionally, the Mattoc Pro saves even more weight through its lightweight cartridge damper. Manitou's Multi Control Compression damper offers high and low-speed compression and an external hydraulic bottom-out adjuster. The Mattoc Pro uses the Manitou’s Dorado Air spring, combining downhill-level performance into an all-mountain fork. The on-the-fly low-speed adjuster allows the rider to dial just the right amount of chassis control for excellent handling and quickly adjust for optimal efficiency without compromising small bump compliance. The high-speed adjuster allows the rider to fine-tune sensitivity over rougher terrain, allowing the fork to float through chatter without losing travel.
Price: $849.99 $749.99
GET DEAL
CANE CREEK DB AIR CS SHOCK - Save 30%
1925600
Cane Creek first broke new ground with the Double Barrel Coil Shock which was a huge success, inspiring confidence with the next level of adjustability and control. Next, Cane Creek devised the DBAir rear shock to accommodate those frames that cannot accept coil shocks and require air rear shocks. Now, Cane Creek's next evolutionary step in rear suspension is here: the Double Barrel Air CS. By adding a Climbing Switch (CS) to the legendary DBAir rear shock, Cane Creek was able to breathe new life into an already well-revered rear shock.
Price: $699.00 $489.30
GET DEAL
PUSH ACS3 ROCK SHOX LYRIK / YARI COIL CONVERSION - Save 35%
1925601
If you have ever talked to someone who has a Push product on their bike, you probably haven’t heard about any negative criticisms. The brand has a reputation for producing some of the best suspension products in the world. The Push Coil Conversion kit converts the air spring of your fork into a coil spring with an air bump stop to control progressiveness. With the new kit, you receive the suppleness of coil suspension with the progressiveness of air suspension. It’s truly the best of both worlds. Continue reading below to learn more about the specifics of the Push Coil Conversion Kit.
Price: $309.00 $199.99
GET DEAL
FOX 32 FLOAT SC FACTORY 29 2020 - Save 10%
1925602
Suspension technology has come a long way in the short time that it has been around and it keeps getting better every year. The 2020 Fox 32 Float Step-Cast Factory Fork starts at 3.06 pounds, which makes this the lightest cross-country fork that Fox has ever made. It is optimized for 100mm of travel and has a Step-Cast lower leg design and a narrow crown spacing that saves weight. The Kashima coating of the Factory series makes the fork buttery smooth and incredibly durable. With the FIT4 damper, you get three positions of compression adjustment so your fork can adapt to the terrain you're on. The remote-compatible version of the fork only features two compression adjustment modes.
Price: $999.99 $899.99
GET DEAL
MRP PROGRESSIVE SPRINGS - Save 13%
1925603
Experience the best of both worlds with the MRP Progressive Spring. Coil suspension has always been superior for small bump sensitivity, but always fell short not being progressive. The MRP Progressive Spring has solved this dilemma for their Hazzard rear shock. Experience a coil shock that is supple off the top and ramps up at the bottom. The coil is produced in many lengths and spring rates to accompany any size rider on any MRP Hazzard shock. Finally run a coil shock on your favorite bike, even if it doesn't have a progressive suspension curve.
Price: $149.95 $129.95
GET DEAL
DVO DIAMOND BOOST 27.5" FORK - Save 25%
1925604
The DVO Diamond Boost 27.5" Fork is a 160mm gem of a trail fork packed with real DH performance. Coming to the industry with the first compression bladder cartridge system, DVO is able to offer unmatched small bump sensitivity. Both low and high speed compression are easily adjusted with external knobs and so is sag thanks to OTT "Off the Top" technology. DVO's OTT design offers simple and accurate air spring tuning. For those particularly mucky days, a handsome integrated fender can be easily installed and removed. Raising the bar in the world of trail and enduro forks, the DVO and the Diamond Boost 27.5" fork may just leave you with a smile on your face and a sparkle in your eye.
Price: $999.00 $749.99
GET DEAL
ROCKSHOX SUSPENSION OIL - Save 5%
1925605
RockShox suspension oil for Rockshox brand forks. Refer to your suspension component's service manual for specified oil volumes and weights.
Price: $20.00 $18.99
GET DEAL
FOX FLOAT DPX2 FACTORY TRUNNION 2020 - Save 10%
1925606
Mountain biking has been revolutionized by the advancements in rear shock technology. Rear shocks add a substantial amount of control over the terrain you're riding on. The ultimate trail shock is here and it is the Fox Float DPX2 Trunnion Factory. The DPX2 has the bump performance of the Float X2 and the lever interface of the DPS. It features a recirculating oil damper in a lightweight and compact package, a one-piece EVOL air sleeve that improves the responsiveness and sensitivity, a three-position lever with an adjustable Open mode to fine-tune the shock, and a Kashima coating. The Trunnion Factory version is designed specifically for bikes that have a trunnion mount.
Price: $599.99 $502.99
GET DEAL
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
