Dark oil (damper?) in Fox fork
2602 Views 27 Replies 10 Participants Last post by  seitenryu
I pulled the lowers from my Fox 34 today and noticed a lot of dark oil in the right, damper side. I thought the bath oil was just dirty, but there was a lot of it and only that side was dark. After a few minutes, I noticed that more oil was dripping from the bottom of damper side stanchion. I wiped everything down and went to another task for an hour. When I returned, there was a puddle of dark oil under the fork, nowhere near the lowers. Dark fluid still dripping from the damper area.
This is a 2016 fork with a Fit4 damper. I've replaced wiper seals and bath oil on it regularly since I have owned it (bought it used) but I have not touched the damper. How do I diagnose what it needs?
  • Like
Reactions: 1
1 - 20 of 28 Posts
A five year old damper that hasn't been serviced?
It's time.
  • Like
Reactions: 2
Oil degrades and darkens with use. Totally normal with lots of use.
Clean it all out and start again.
  • Like
Reactions: 2
derp, yeah, I should have just started with "this thing has had the piss ridden out of it and a neglected damper."
follow up questions:
  1. how do I know if it needs to be bled, or rebuilt?
  2. can I trust myself to DIY either of those jobs? I guess that's a personal question.
  3. considering the cost of the tools involved and questionable overall condition, should I seek out a deal on a Grip2 damper or some alternative?
Go just halfway down the page until you see the header Ford Damper Cartridge Service. Not sure which Fit4 you have but the manual and pictures will give you an idea of what you're in for.
I was reviewing those procedures and the main problem is that I need about $200 in tools for a job I will do so very rarely, plus a blowtorch! I can't justify that purchase. the job also looks very intimidating. I build wheels and do basic lowers maintenance on my own with no problem. I also can't find a mechanic nearby who will touch it. unless I find someone willing to do the job — the parts kit is only $25 — I'll try bleeding it to get a few more rides out of it until it needs more attention.
Which is why you usually have to send the damper or the whole fork to your nearest Fox service center. Some shops can do it if they have their own little suspension service desk, but I guess that depends on how big they are.
The fork was 140mm when I got it, and the seller gave me a 130mm air shaft. I ended up dropping it to 120mm after a few rides. however, I am looking around at replacement damper assemblies and some are listed for 130–160mm forks at some online retailers. no mention of the damper assembly designed for 120. I did this probably two years ago, but I remember asking around to see if I needed to change anything else when lowering the fork travel. is it possible that I made my fork too short for my damper, and that might lead to more trouble down the road?
no
  • Like
Reactions: 1
1. If your damper is slurpy, leaking or has a swollen bladder then it needs serviced. Otherwise go on time and riding.
2. Depends on your.
3. Grip2 stock is nothing special. I'd get Vorsprung Tractive put into a FIT4 long before fitting GRIP2.
  • Like
Reactions: 1
assuming this does not cost half of what a new fork might cost me, I'm dropping this off at a shop today. that's the first time I've had to do that since I was... 14? I found a few shops who can do the work in-house. I like to work on my own bike, but I draw the line at $200 in special tools that I'll use once, and the fact that I need to take a blowtorch to my bike to complete the job.
Can the shop do Vorsprung Fractive? It's the same labour to install that as to service a FIT4. Just a bit more time to pick out a tune.
It will turn the FIT4 from something average into something excellent.
  • Like
Reactions: 1
who here has performed this service at home? I don't have any of those proprietary tools, and I might DIY it if I can buy the tools at a cost that makes it worthwhile. I see some alternatives to the rod clamp for $25-30 on Etsy and Ebay instead of the $100+ unit from Fox. do I need those "bullet" tools, or do those just make assembly easier? the instructions look intimidating, but if all I need is a shaft clamp, bleed syringe, and a rebuild kit, I might dive in on my own. I have a table vice, torque wrenches, and all the other standard tools that I can imagine.
edit: nope, that process looks frustrating. if I owned more than one mountain bike and could be patient with fixing this one while I take my sweet time doing this, perhaps. every day that I spend with this fork not working is a day I spend not riding.
Have you removed the damper from the fork? If it is still functional and the bladder hasn't ruptured you will be ok just to basically just remove the sealhead and bleed/LSC screw (careful with the circlip!) flush out the internals with cleaner and reassemble.
If the bladder is so swollen it won't slide out of the stanchion easy, or the oil inside the damper is super dirty then it would be best to replace the seals but even then you could do a really good clean and bleed to keep it going until you have some more time.
For that you only really need the body clamps (17ish mm) and bleed syringe.
Damaged bladder or other potential wear/issues - take it to a pro
You probably won't need a blowtorch but a heat gun will substitute fine as well. If you don't have a heat gun either you need to buy one!!
  • Like
Reactions: 2
Do what JohnnyC7 said. I’ve bled one and it’s not difficult, just some patience. Although I chose the wrong diameter tube at first and frayed the o-ring that seals inside the LSC adjuster but that’s another story and it shouldn’t happen to you.
You don’t need special tools to bleed it, only a syringe with a plastic tube and damper oil. Start from step 38 in Fox’s instructions. And put your thumb on that circlip!
My concern with just a bleed is that it's currently leaking fluid into the lowers. If there's a worn out seal somewhere, a bleed won't help that, right? It would still need to be torn down and replaced.
Thats why I asked if you have removed the damper, if the bladder is very sucked in and feels very aerated then it has probably leaked. If it seems relatively normal then its fine.
The extra oil that dripped out was possibly just what was clinging to the inside of the stanchion, which can take a few minutes to fully run out
sorry for the lack of specifics. Here's the damper with the shaft extended:
Cosmetics Cylinder Liquid Auto part Solvent
and compressed:
Liquid Cosmetics Tints and shades Bottle Office supplies
I've cycled it a few times outside of the fork like this and I can't seem to get any more fluid to ooze out anywhere. I left it in a compressed position for a while and I didn't see any additional leakage. that makes me think it's not all that bad but the fluid is probably ancient. I'll have to acquire some damper fluid and try to bleed it, then check for excessive oil the next time I take the lowers out.
I would advise that you do a full service - including the replacement of the sealhead, as it has probably worn out the seal and will ingest more bath oil as it works.
Stefan
Oil volume wise that bladder looks perfect, at full extension it’s “relaxed” ie not sucked in or bulging at all.
Damper seal heads will always gradually ingest oil, Fox forks normally take a long time though. Depends on use, frequency of services and type of oil used.
personally I wouldn’t worry about trying to change the seal head yourself, in all honesty they are so reliable you are more likely to cause a leak than prevent one
1 - 20 of 28 Posts
