Cato said:
I'm about ready to install a new fork and am not sure that I should invest in Park's saw guide to cut the tube. Has anyone used other alternatves, and with what results?
I have used the following methods with success: Piece of tape, pipe cutter, an old stem, Pa
rk saw guide.
Pipe cutter took a while, I'd rather use a hack saw.
As long as you are careful, work slow, and can stay on course, a piece of tape as a guide works just fine.
The old stem trick, personally I thought it was easier just using a piece of tape.
Using the Park guide makes the task simple, fast, accurate, and brainless.
How many forks do you plan on cutting in your lifetime? The guide is $25. All things considered, it is worth it to me.
