So on sizing chainstays to length and taking into consideration tube butting, tire clearance, bend of stay, and beltring clearance issues.
Is there a "best" way to approach this? Is there a sweet spot for the bend in the stay? (when the axle/do is completely open/ completely closed/ middle?
No reason not to double check my thoughts with the best!
Here are the specs:
What I want to end up with:
When in doubt...draw it out. (was actually pretty fun to do.
There are 2 pictures.
One shows the right chainstay HIGHER/CLOSER on the BB (this put the 'bend' in the stay closer to the actual tire when the dropouts are completely "closed.' Not good for chainring clearance. BUT I could technically lightly crimp the inside of stays and have more clearance overall.....(hmmm)
The other picture has the chainstay LOWER/FURTHER AWAY on the BB drawing (hence dropping the bend in the stay lower in the stay. From the pic this would also allow better beltring clearance (have a 39 tooth ring ready to go)
Thanks in advance. Only reason I ask is there was a post on Frame Forum and the poster seemed to elude that cutting/mitering the DO chainstay side was correct.
Thanks in advance.
Cheers.
Here are the specs:
- 26x18 Oval/12° Bend HOX5CS (True Temper chainstays)
- Ride Goals: Singlespeed Beltdrive (with blackcat swinger dropouts)
- 440 CS length (min) This is what the picture is showing.
- 2.1 Tire (so I went with 56 mm width in the drawing ...then added the 5mm MIN of tire/stay clearance to each side as Walt from Waltworks pointed out on a blog. By the way....same Walt on this forum right? :thumbsup:
Thanks in advance.
Cheers.
