Do I need to use a knife to pry it open?
Can I swap old cells with new cells 18650?
Sent from my SM-G965W using Tapatalk
in all honesty
if you have to ask these questions
you maybe shouldn't do any mods
you could start a violent or explosive fire, die from fumes...any number of bad things
or....do the deed think it's good and later have a fire start while you are out riding
to pry it open you use a proper sized spudger and dremel w/cutting disc for any glued or fused bits... with extreme care. not a knife
to replace 18650 you need a spot welder to do it correctly...as soldering is problematic on 18650's due to time and heat. spot weld is
fast and doesn't heat up the cell
the charge circuit needs to be taken into account...will it work correctly with your replacement cells
should really just get a battery case, use your own 18650's, and solder up the dinotte pigtail to that
and then charge the cells in a regular loose cell li-ion charger. skip trying to hack the dinotte pack
