1 - 15 of 15 Posts
Discussion Starter #1
I am looking at getting a set of custom built 29er wheels for my TB3. I called Salt Cycles and got a good price on a set of 28mm id w/ DT350 6 bolt, CX Ray spokes. They claim/estimate the weight to be about 1385 grams. They said the carbon hoops come from asia (as most do). 32H
I checked another online shop (speed gear bike) and they offered the same build but on 27mm id hoops from Light Bicycle. There seems to be about a 200 gram difference in total wheel weight. 32H. They were about $100 cheaper too.
Seems to be a significant difference. The Salt cycles wheels seem exceptionally light.
Ideas as to why such a big difference? Anyone get wheels built from either of these places?
Wanna ride bikes?
How much do you weigh? Where and how do you ride? Is the goal to have a super light wheelset meant for racing or are you looking for an all-day every day wheelset? It's important to match the rim to the application. If the rim is too light, the fact that it's 32h won't save you from an expensive mistake.
What is the brand of the no name mysterious carbon rim? I wouldn't trust anything I didn't know exactly where it comes from and exactly how much it weighs.
Light Bicycle makes good rims and is a known quantity.
Unless you weigh 125lbs, I wouldn't recommend any wheelset that weighs under 1400g, especially if you don't know what rim it is. It's unlikely to be reliable.
Discussion Starter #3
Unless you weigh 125lbs, I would recommend any wheelset that weighs under 1400g, especially if you don't know what rim it is. It's unlikely to be reliable.
I weigh about 170lbs. I ride aggressive XC in the southeast. Wooded, rooty trails, small drops/jumps. This will be my only wheel set.
Wanna ride bikes?
Discussion Starter #6
Links to the exact rims would be helpful. Assuming this is one? https://www.lightbicycle.com/AM927-asymmetric-rim-profile-carbon-29-inch-carbon-rims-mtb.html
The "Pro" description says 3-5% stronger (BFD), lighter, and has a satin finish.
What's the priority, weight, price, looks? What is the difference in price vs weight?
Yes, those are the LB wheels I was looking at. I am leaning towards light weight even though I do not race. Basically a light duty trail wheel. I am currently on 27.5'' Enve M60 Forty 40mm id wheels laced to DT blade type spokes and DT 350 hubs w/54T. Not sure what these wheels weigh, I have seen in the mid 1400-1600g area.
Option 1
29" w/28mm id (brand unknown, asian manufactured), DT350, CX ray spokes. I was told 1385g. $1250
Option 2
29" w/27mm id, (light bicycle, recon pro, DT350, CX ray spokes, 1635g, $1148
Option 3
29" w/28mm id, (light bicycle, recon, DT350, CX Ray spokes, 1705g, $998
The seller of option 1 said there is only 3-4 manufactures of carbon wheels. I believe it. However, that does not mean that they are all the same. From what i see, almost everything comes from China/Asia. It is up to a brand to be the face of said product and offer the customer service that goes with it.
Formerly of Kent
I don’t know that I’d buy a 1700g XC wheelset for $1100+. That’s highway robbery.
How do you even build a carbon wheelset that heavy for that purpose using 350s?
With a 450g, 590 ERD rim, using DT Swiss Aerolites (CX-Ray equivalent) and Boost 350s with 32h drilling, the DT Swiss spoke calculator says the wheelset would weigh 1616g.
Live Free & Ride
Discussion Starter #9
BTLOS is the retail site for the one manufacturer who makes all the carbon rims for LB, CarbonFan, etc.
I wouldn't get CXRay spokes for mountain bikes. Lasers are the round version with near the same specs at 1/3 the price per spoke.
And get brass nipples to avoid the corrosion possibility in a couple years. I'd recommend BTLOS and an asym rim wheelset at least 30mm inner for XC 2.3" tires.
When they give a plus or minus for a rim weight request something at the low end of the range in the comment box.
Live Free & Ride
+1 on BTLOS...
Here is a 1670 gram config using i30 asym rims at $776:
Rim Size: 29er
Series: Premium
Version: AM
Finish: Matte
Weave: UD
Spoke Count: 28H/28H
Hub Type: DT SWISS 350
Ratchet: Upgrade 54T
Hub Color: Red
Front Axle: 15*110mm BOOST
Rear Axle: 12*148mm BOOST
Freehub: Shimano Microspline
Brake Interface: Center Lock ( Disc )
Spoke: Sapim D-Light
Spoke System: J-bend
Nipple: Brass Black
Discussion Starter #12
They have a good website! I just priced the following
29
premium
WM i29A
matte UD
28H
DT 240
54t
boost
XD
6 bolt
CX ray
j bend
brass
1470g $995
$180 less for DT 350
Seems like a really nice wheel. Thank you for sharing that!
I am not sure what I give up or if it even matters to me the 2.6 vs 3.5 mm thickness on the WM I29A vs the WM I30A.
What's up with red DT Swiss 350's? Must be Chinese knock off's
I ordered a set of BTLOS wheels and I had the same question about the red color. Their response was that the black with white label is the standard color and red is not available. So even though it currently shows up as an option for red hubs, its not available for the DT-350's.
1 - 15 of 15 Posts
