Does anyone know a bike co or frame builder that can build a custom DW-Link frame? I can't quite find the frame I'm looking for from the various DW-Link builders out there (Iron Horse, Turner, Pivot, Ibis). I really want a 5" travel (front & rear) bike that's more XC than AM, but not so much XC that it's twitchy or whippy.
Here's what I'm looking for in geometery specs:
Head tube: 4"-4.33" length Tapered head tube with a 1.5" at bottom tapered to 1.125" at the top with zero stack
Seat tube: approximately 17.5" from center of BB to top tube
Seat post diameter: 30.9 mm
Head tube angle: 69.5 degrees
Seat tube angle: 72.5 degrees
BB height: 13"
Effective top tube length: 22.75"
Chainstay length: 16.75"
Other: sealed cartridge bearings at all pivots, setup to use a Fox RP23 7.5" x 2.0", disc brake only, cable routing on the underside of the top tube setup so I can run full derr housing
ideal otal frame weight with shock: 5 - 5.5 lbs
Is this possible? Thoughts?
BB height: 13"
