I have had TREMENDOUS problems with chain suck on my Ibis Mojo. I keep my drivetrain clean and lubed but not over-lubed, I've swapped the BB spacers to try to improve chainline, I installed zip ties underneath to prevent the chain from following the chainring around, currently using a Wipperman chain, have sanded the chainring teeth with 800 grit wet/dry sandpaper to polish the surfaces, all suggestions have been tried.
While talking to a fellow Mojo owner on the starting line of the Breckenridge 68 this past Saturday, the conversation turned to chainsuck. He said he put Shimano XT rings on and it cured his chainsuck. He believes the steel middle ring fixed the problem.
So I set off in search of acquiring a steel XT middle ring. During my search, I found out that Shimano makes a steel granny in their SLX line. So I'm absolutely going to buy the steel XT middle ring, but am considering purchasing the steel SLX granny to go with it.
Would a Shimano SLX FC-M660 steel 22t granny have any problems working with a Shimano XT FC-M770 steel/carbon 32t middle ring?
