Do you need to save and reuse the crown race or can you destroy it in the process of removing it? Cut it off?
Come on man... You used a pizza cutter.Last one I removed in a pinch I used razor blades.
How can i cut it but now damage the fork its self ?Do you need to save and reuse the crown race or can you destroy it in the process of removing it? Cut it off?
YESOk ok it was two pizza cutters. One rammed in each side
Maybe a hacksaw oriented parallel to the steerer tube, aiming down towards the crown? Stop before you cut through into the crown and break it open the rest of the way. Just an idea. Not sure if it would work.How can i cut it but now damage the fork its self ?
I reckon if it's not welded on there it would work well.I used razor blades on my last stuck race. Tap a blade in on one side careful not to go in too deep and mark the steerer. Tap one in on the other side. The add a 2nd on the 1st side. Add a 2nd on the 2nd side. Just keep adding blades until the crown race comes off. They act like little wedges and push the race off.
Because both the race & the steerer tube are both steel their thermal expansion rates are same unfortunately..........I'd suggest heat, while it's true that metals expand at different rates, usually a larger concentric ring is going to expand significantly due to significantly longer circumference. So even if the inner metal has a higher rate of expansion, the outer ring ends up lengthening more with a subsequent radius change due to circumference being longer and having more to play with.
But you have also beat that to hell already. Given that, it's likely it's bonded on there through a chemical process. The cutting is probably the best way for results at this point, don't cut all the way through like suggested above, just get close. This tends to work for a lot of frozen stuff.
Put the whole thing in a freezer for half a day. Metals shrink at different rates -- might be enough.
Or given the wedges you've driven under there, it might not.
Crown race removal tools (the bearing splitter you posted) frequently destroy crown races, unless the blades can get all the way under a significant portion of the race. It is compounded by the tight fits/small gaps on that type of bearing race you posted. If the goal is to re-use the race, more times than not, you are better off with the following method--due in large part to the fact that suspension forks have no crown race overhang.Because both the race & the steerer tube are both steel their thermal expansion rates are same unfortunately..........
And it didnt help.........
The freezer is full and has no space ............but dont think it would help either as i used boiling water..............the temperature difference with the room temp was about 80 C.......the freezers temp is about -15 C so ots difference with the room temp is around 35 C But after all..............il give it a try................maybe use some ice on it..............
Because the race has a longer circumference, it would expand more than the steerer. That's why you use heat...but I think it's too stuck for heat anyway.Because both the race & the steerer tube are both steel their thermal expansion rates are same unfortunately..........
