1 - 4 of 4 Posts
Has anyone done the conversion from the QR to the 20mm on their front hub? I just picked up a Pike and ordered the conversion parts. What is required to make the switch? Any help is appreciated.
Premium Member
We did not know when you posted the same question yesterday. Try the shock board or contact Mavic directly.
friend of preston
easy...
remove the QR caps, to do this you may need to pull the rotor, replace with the 20mm caps and install rotor, brake and wheel, roll away.
1 - 4 of 4 Posts
