1 - 12 of 12 Posts
keystone addict
I think it toast, but is there any way to fix it? the first half of the threading is now shiny, smooth metal. :madman:
If it's toast, anybody know how to get one, or where to get one the cheapest?
tried derrailleurhanger.com (or someting like that), but they didnt have the vpfree model.
Meh.
Your LBS might have a "drop-out saver kit." It's a tap and a helicoil. But since youre hanger is aluminum, I don't know how well the helicoil will stay in. IMO, it's not worth it. If you do repair it, keep it as a spare, throw a new one on. Just shell out and pick one up from Santa Cruz or a SC dealer.
Now with flavor!!
You can also t-bolt it as an alternative to a helicoil. Most good bike shops should have one. I did it to two of my dh bikes and they work great.
Sugary Exoskeleton
Yes... I have done something similar...
Tap the derailleur mounting bolt (if it's SRAM, it should be alloy, and hollow) to 6mm thread, then bolt through the back with a flat head bolt (anything that sticks out will interfere with your 11t cog)
It sandwiches your hanger between the bolt head and the derailleur. Works great!
JMH
Some Assembly Required
You could always just use a Saint rear derailleur (mounts to the rear axle). Just an idea, especially if your hard on derailleurs, or planning on up grading.
Those are the best things ever made. We use them all the time at the shop I work at. It is hands down the best way to solve the problem, with the exception of this one since the hanger is replacable. BUY A NEW HANGER
1 - 12 of 12 Posts
