Why is it that cross country and race mountain bikes do not use modern geometry such as steep seat tube angle and longer top tube reach as is common in modern trail bikes?
The seat tube on longer travel bikes that sag when you sit on them is steepened to replicate how it already is on shorter travel bikes. Reach has increased, seat tubes have steepend, but the seat tubes especially are not as dramatic on the longer travel bikes for the above reason. You also already have a good # of weight on your hands due to the shorter travel and steeper HA, what the radical geometry enduro bikes are not great at is all-around flat-terrain riding geometry, going up is decent because of the new changes and going down is ok because of the dropper post, although some are arguing the steeper seat tube puts too much weight and pressure on their hands, but in any case, these changes aren't going to be as radical for XC race bikes. To put it simply, unless it's going to make you faster, there's no point.Why is it that cross country and race mountain bikes do not use modern geometry such as steep seat tube angle and longer top tube reach as is common in modern trail bikes?
Because they have less travel AND run less sag than trail bikes. So they don't sink nearly as far backwards when going uphill.Why is it that cross country and race mountain bikes do not use modern geometry such as steep seat tube angle and longer top tube reach as is common in modern trail bikes?
Hmm. I notice that my V4 Ibis Ripley seems to have better more comfortable climbing geometry than a Pivot les 29 I have ridden. 76 degree sta Ripley vs 72 degree sta on les 29. I felt I needed to push the seat forward on the les 29 to get it to feel similar after I was accustomed to the Ripley. And when I look at other manufacturers bikes for cross country /race (Specialized, Orbea, Scott, etc,) the geometry seems quite similar. Sta has little effect on downhill prowess. As one is typically not seated.As Jayem said, XC bikes are optimized for uphill speed and overall handling. Not just the ability to go downhill fast, while suffering up the hill. I've ridden modern trail and enduro bikes, and despite what some will claim, they are still garbage at going uphill compared to a proper XC bike. Different league entirely.
I just read 73.5 for the Epic hardtail. That's a long way from 76 IMO. The Pivot is 1 degree slacker, except for the small, which is only half a degree slacker.Hmm. I notice that my V4 Ibis Ripley seems to have better more comfortable climbing geometry than a Pivot les 29 I have ridden. 76 degree sta Ripley vs 72 degree sta on les 29. I felt I needed to push the seat forward on the les 29 to get it to feel similar after I was accustomed to the Ripley. And when I look at other manufacturers bikes for cross country /race (Specialized, Orbea, Scott, etc,) the geometry seems quite similar. Sta has little effect on downhill prowess. As one is typically not seated.
PivotLESI just read 73.5 for the Epic hardtail. That's a long way from 76 IMO. The Pivot is 1 degree slacker, except for the small, which is only half a degree slacker.
What are you smoking?
S | M | L | XL | ||
a Seat Tube | 16in | 17.75in | 19in | 21in | |
b Effective Top Tube | 22.9in | 23.9in | 24.5in | 25.5in | |
c Stack | 23.96in | 24.13in | 24.83in | 25.64in | |
d Reach | 15.57in | 16.29in | 16.66in | 17.43in | |
e Stand Over | 28.5in | 29.2in | 29.6in | 29.7in | |
f Head Tube | 3.85in | 4in | 4.45in | 5.5in | |
g Head Tube Angle | 69.3 | 69.5 | 69.5 | 70 | |
h Seat Tube Angle | 73 | 72.5 | 72.5 | 72.5 | |
i Bottom Bracket Height | 12.1in | 12.1in | 12.1in | 12.1in | |
j Bottom Bracket Drop | |||||
k Chainstay | 17.1in | 17.1in | 17.1in | 17.1in | |
l Wheelbase | 42.58in | 43.27in | 43.9in | 44.74in |
My bad, 72.5 for the Pivot, except the small at 73 and 73.5 for the specialized.PivotLES
SL Carbon Race XT Mountain Bike
My point still stands.
It's a long way from 76 and what are you smoking?
The geometry is in no way what you are making it out to be in your original post. The SA is one degree or less apart, so your point isn't based on reality.
A steep seat tube angle puts more weight forward on a climbing bike. Climbing semi steep (to steep) trails with older geometry bikes, one had to slide very far forward on the nose of saddle to keep the front tire on the ground. If one stood on the pedals the back tire would probably slide out. The steep seat tube angle bikes do not require much saddle maneuvering on the steep climbs. Just keep on pedaling. Steep seat angle aids in climbing. And has little effect on down hill handling. Aero dynamics, which are less of a concern on mountain bike than road bike, is probably more a factor of stack height and handlebar width.Modern geometry also takes weight off the front end making it harder to corner fast on flat corners while running low rolling resistance XC tires.
A quick question for you. Do you own a modern XC bike yourself?A steep seat tube angle puts more weight forward on a climbing bike. Climbing semi steep (to steep) trails with older geometry bikes, one had to slide very far forward on the nose of saddle to keep the front tire on the ground. If one stood on the pedals the back tire would probably slide out. The steep seat tube angle bikes do not require much saddle maneuvering on the steep climbs. Just keep on pedaling. Steep seat angle aids in climbing. And has little effect on down hill handling. Aero dynamics, which are less of a concern on mountain bike than road bike, is probably more a factor of stack height and handlebar width.
I had no idea this would be such a contentious thread.
I guess at 74 degree seat tube angle, you are getting closer to the sweet spot. This post has seemingly has turned into a me against the world argument. I should probably reluctantly assume that the world is right. But dammit, not without first putting up a good fight.I wasn't trying to be contentious so I hope I didn't come across that way. I can't speak for the others.
I have never had problems with front end lift even on a 74 degree seat tube and I ride some pretty steep stuff. Wind resistance is the primary form of resistance above 12mph and nowadays, many XC track average speeds are above that. Look at the local Cat 1, national and Word cup races. People are generally wearing very tight fitting clothing with aero helmets
Nothing wrong with asking the question.This post has seemingly has turned into a me against the world argument. I should probably reluctantly assume that the world is right. But dammit, not without first putting up a good fight.
