1 - 8 of 8 Posts
Hi some one mentioned this idea some where here or on CPF site
so I thought I will give it a try .
Clicky switch from an old mouse , also have 2 spare switches if this works.
this is my rear cover for my build with the switch glued in
The other side showing the hole and little clicky switch
next the question of waterproofing and working the switch ,
as you can see the recessed hole it looks out from the answer was so simple
an old innertube punch a disc of rubber out and glue a very small dot of innertube in the centre this will be silicone glued round the edge when finished but for now is just a compresion fit , resuly one waterproof and nearly touch sensitive switch for the Bflex
Will this work .
next step some wiring and assembly and testing
could you show a picture of the mouse switch on its own if possible along with some dimensions. Obviously they will vary mouse model to mouse model but an indication of dimensions would be great
Discussion Starter · #6 ·
here is the finished light and it works way better than expected the switch is easy to operate even with cold hands and gloves on , very happy to have made this work and have a very sleek mega powerfull light for about £60 . I do need to get a good battery next I am using a 14.4 volt makita drill battery and it is working well but a bit ugly and bodged connections.
this one is for on my helmet the next project is one for my bars will the Bflex drive 4 cree xr-e Q5 leds
Nice!
Nice work with the switch, it looks like a perfect solution!
From what I have read, the bflex will drive 4 LED's but you will need a higher voltage battery for this, as a 14.4V battery will be marginal. 3LED's are no problem of course with a 14.4V battery.
1 - 8 of 8 Posts
