1 - 11 of 11 Posts
Hi there
I have a santa cruz heckler which has a raceface x type crank.The rest of the drivetrain is shimano xt.It has developed an annoying creak under heavy load when climing.I have tried tightening,lubing,adjusting nothing seems to cure it!!!! I have just replaced the bb which also has made no diference,the chain is also new.Could the rear mech cause a noise like this ??? Any ideas welcome
thanks
mark
Custom User Title
markyboy said:
Hi there
thanks
mark
My pivot always made a little noise on my Heckler.
Old man on a bike
Creaks can be elusive as you're discovering. Helps if you're specific about what you've tried already. I saw in your other post you've had the bike 8 months; while it's possible it's pivot creak, checking your seat post collar, seat rail clamps, derailleur hanger dropout, skewer tightness, chainring bolts, pedals, shock mount bolts....the list goes on...
$50 says it's your dropout
I have a 2004/5 Heckler and had the same issue. I replaced the bottom bracket several times, cleaned everything greased and re-greased countless time. Removed the shock and swingarm 4-5 times. Cleaned and greased everything. All bolts perfect tightend to spec with a torque wrench. Then, I did what you have done and posted on here for suggestions. Several people said they had the same thing happen with their dropout. So, I took it off. Cleaned it and put a thin layer of grease on the surfaces where metal comes together. I also used blue loctite on the dropout bolts. The creaking is 95% gone. It raised its' head occasionally though but I am a 240lbs rider. So, I probably put more torque down on those pedals than lighter riders. Some people suggested getting the dropout alligned at a good Santa Cruz dealer. I never did this but it probably would not be a bad idea. I just don't like having to leave my bike anywhere for a few days waiting on them to get the job done.
CC
I went through this a couple times.
The first time my main pivot bearings were completely shot and since then it was always the dropout........just lube it up with some thickish grease, i use axle grease there.......will take the creak away.....
Baby-heads.... oh joy!
Another for the chainring. Check the chainring bolts, and also if the chainrings are worn. mine was making some serious noise, just ended up I needed new chain rings...small and middle..did the trick. Of course, there are the other areas as others have stated.
1 - 11 of 11 Posts
