I am getting a creaking noise that is in time with the crank rotation and can't seem to figure out the source. I have greased the crank spindle threads, the pedal spindle threads, the fixing bolt threads, and sprayed WD40 on the mounting bolts, and frame area. None of this had any effect. My bike is built up from parts that came from a Focus hardtail which had no noise issues. The bike was pretty quiet for the first week but is getting more noticeable. My next step is to pull the motor and grease the frame tabs, and if that doesn't do it, then I can only conclude it's in the motor itself. I don't think it is a suspension pivot issue, because just bouncing on the bike does nothing, it only happens when pedaling, with or without power. Also if I lay the bike on its side and push the crank arm inward I can initiate a single creak, and then flip it over and get the same thing on the other side. It is very reminiscent of a BB problem, but there is nothing to service on the E8000.
Has anybody had any issues like this?
